The SP can be reset to any of the following states:
None, which retains the existing configuration if the SP is reset.
All, which resets the SP to the system default properties.
Factory settings (the most severe), which resets the SP to its initial state when shipped from the factory.
Use this task to reset the SP.
-> set /SP/ reset_to_defaults=none Set 'reset_to_defaults' to 'none' ->
-> set /SP reset_to_defaults=all Set 'reset_to_defaults' to 'all' The configuration change will be applied the next time the SP is reset. ->
-> set /SP reset_to_defaults=factory Set 'reset_to_defaults' to 'factory' The configuration change will be applied the next time the SP is reset. ->
