Oracle EDR InfiniBand Switch and Virtualized I/O Systems Administration Guide
Exit Print View
Updated: November 2016
Add Alternate LDAP over SSL Servers (Oracle ILOM Web)
Typically, LDAP over SSL networks have multiple alternate LDAP over SSL servers. The switch supports a maximum of five LDAP over SSL servers plus the primary.
  1. Choose ILOM Administration→User Management, and click the LDAP over SSL tab.
  2. Click the Alternate Servers link.
    The pane scrolls the Alternate Servers section.
  3. Select a row on the Alternate Servers table even if the table is empty.
  4. Click Edit.
    A pop-up window is displayed.
  5. Enter the IP address or host name of the alternate LDAP over SSL server.
  6. Select the port for communication with the LDAP over SSL server:
    • Select the AutoSelect checkbox if you want the port automatically determined.
    • Deselect the AutoSelect checkbox, and enter a port number in the Port field if you want to specify the communication port.
  7. Assign an SSL certificate to the LDAP server.
    See Load Certificate Information for an LDAP over SSL Server (Oracle ILOM Web).
    Note -  You can also remove an SSL certificate through this window, by clicking Remove Certificate.
  8. Click Save.
Related Information
