sunHwTrapDriveControllerFault
Trap is generated when a drive controller component is
suspected of causing a fault.
sunHwTrapDriveControllerFaultCleared
Trap is generated when a drive controller component fault is
cleared.
sunHwTrapFanFault
Trap is generated on a fan fault.
sunHwTrapFaultDiagnosed
Trap is generated when a diagnosed fault has been detected.
sunHwTrapFanFaultCleared
Trap is generated when the fan fault is cleared.
sunHwTrapProcessorFault
Trap is generated when a processor component is suspected of
causing a fault.
sunHwTrapProcessorFaultCleared
Trap is generated when a processor component fault has been
cleared.
sunHwTrapMemoryFault
Trap is generated when a memory component is suspected of
causing a fault.
sunHwTrapMemoryFaultCleared
Trap is generated when a memory component fault has been
cleared.
sunHwTrapHardDriveFault
Trap is generated when a hard drive component is suspected of
causing a fault.
sunHwTrapHardDriveFaultCleared
Trap is generated when a hard drive component fault has been
cleared.
sunHwTrapIOFault
Trap is generated when an I/O subsystem is suspected of
causing a fault.
sunHwTrapIOFaultCleared
Trap is generated when an I/O subsystem component fault has
been cleared.
sunHwTrapPowerSupplyFault
Trap is generated on a power supply fault.
sunHwTrapPowerSupplyFaultCleared
Trap is generated when the power supply fault has been
cleared.
sunHwTrapSlotOrConnectorFault
Trap is generated when a slot or connector component is
sunHwTrapSlotOrConnectorFaultCleared
Trap is generated when a slot or connector component fault has
been cleared.
sunHwTrapStorageVolumeFault
Trap is generated when a storage volume is suspected of
causing a fault.
sunHwTrapStorageVolumeFaultCleared
Trap is generated when a storage volume fault has been
cleared.
sunHwTrapComponentFault
Trap is generated when a component is suspected of causing a
fault.
sunHwTrapComponentFaultCleared
Trap is generated when a component fault has been
cleared.
