Oracle EDR InfiniBand Switch and Virtualized I/O Systems Administration Guide
Exit Print View
Updated: November 2016
Alert OIDs
This table lists alert object identifiers supported by the SUN-ILOM-CONTROL-MIB MIB.
Description of Task or Activity
Action
MIB OID
Display or set the minimum event severity that should trigger an alert, for a given class.
read
write
ilomCtrlAlertSeverity
Display or set the type of notification for a given alert.
read
write
ilomCtrlAlertType
Display or set the email address to send alert notifications when the alert type is email(1).
read
write
ilomCtrlAlertDestinationEmail
Display or set the version of SNMP trap that is used for the given alert rule.
read
write
ilomCtrlAlertSNMPVersion
Display or set the community string to be used when the ilomCtrlAlertSNMPVersion property is set to v1 or v2c.
Display or set the user name to be used when the ilomCtrlAlertSNMPVersion property is set to v3.
read
write
ilomCtrlAlertSNMPCommunityOrUsername
Display or set the destination port for SNMP traps.
read
write
ilomCtrlAlertDestinationPort
Display or set the class name on which emailed alerts are filtered.
read
write
ilomCtrlAlertEmailEventClassFilter
Display or set the type name on which emailed alerts are filtered.
read
write
ilomCtrlAlertEmailEventTypeFilter
Display or set an optional format to identify the sender or the from address.
read
write
ilomCtrlAlertEmailCustomSender
Display or set an optional string added to the beginning of the message body.
read
write
ilomCtrlAlertEmailMessagePrefix
Display or set the address to send alert notifications when the alert type is snmptrap(2) or ipmipet(3).
read
write
ilomCtrlAlertDestinationAddress
Related Information
