(Optional) Set the RADIUS Shared Secret (Oracle ILOM Web)
If the RADIUS implementation in your network uses a shared secret, you
must configure the shared secret on the switch also. Use this task to
configure the shared secret on the switch.
Choose ILOM Administration→User Management, and then click the
RADIUS tab.
Select the Enabled checkbox for State.
For Shared Secret, click Change.
Type the shared secret passphrase for the server.
Note -
You can also reset this field to its previous value by clicking
Revert.
Click Save.
