The serial connection must be configured with properties that match at the switch end and host end of the connection. Use this task to set the serial connection properties, such as flow control and connection baud rate, for the host end of the connection. Configuring the serial connection requires you to commit the properties. To commit the pending properties, the serial console cannot be in use.
-> set /SP/serial/host/ pendingflowcontrol=software Set 'pendingflowcontrol' to 'software' ->
-> set /SP/serial/host/ pendingspeed=115200 Set 'pendingspeed' to '115200' ->
-> set /SP/serial/host/ commitpending=true Set 'commitpending' to 'true' ->
