Display the Switch System Log (Oracle ILOM Web)
The system log contains SP events that occur for specific subsystems or event
types. When an event occurs, it is posted to the system log, where it is kept
until the log rolls or is explicitly cleared.
Choose System Log.
For each SP event, the table displays an ID, the date, time, and a brief
description of the event, the event type, and the affected subsystem and
parent component.
(Optional) Use the control buttons on the bottom toolbar to move through a
multipage table.
Click the Go to First Page button to display the first page of the
table.
Click the Previous Page button to display the previous page of the
table.
Click the Next Page button to display the next page of the
table.
Click the Last Page button to display the last page of the
table.
(Optional) Use the Filter dropdown menu to sort the table based on pre-set
conditions or create a custom filter.
You can filter the log by affected subsystem or event type.
