Oracle EDR InfiniBand Switch and Virtualized I/O Systems Administration Guide
Exit Print View
Updated: November 2016
Remove a Certificate From an LDAP over SSL Server (Oracle ILOM Web)
Some situations might require you to remove an existing certificate. For example, if the switch is no longer using Strict Certificate mode, or if a certificate expires and must be replaced with a new one, you must remove the existing certificate.
  1. Choose ILOM Administration→ User Management, and click the LDAP over SSL tab.
  2. Click the Certificate Information link.
    The pane scrolls to the Certificate Information section.
  3. Click Remove Certificate.
  4. Click Save.
Related Information
