You can disable the FIPS service if a data transmissions is not pending. Some other services are blocked when FIPS is enabled, so disabling FIPS enables some other features to become available, such as:
LDAP can be enabled when FIPS is disabled
RADIUS can be enabled when FIPS is disabled.
IPMI 1.5 sessions can be enabled when FIPS is disabled.
To enable FIPS, you must reboot the SP, which also clears the configuration.
A pop-up window prompts you for confirmation.
The SP is reset. Any active sessions are terminated.
