Oracle EDR InfiniBand Switch and Virtualized I/O Systems Administration Guide
Exit Print View
Updated: November 2016
Hardware Traps
This table lists the hardware traps supported by the SUN-HW-TRAP-MIB MIB.
Note -  For all threshold traps, the sunHwTrapThresholdType object indicates whether the threshold is an upper threshold or a lower threshold.
Trap or Notification
Description
sunHwTrapComponentEnabled
Trap is generated when the component operational state has changed or is changing to enabled.
sunHwTrapComponentDisabled
Trap is generated when the component operational state has changed or is changing to disabled.
sunHwTrapComponentError
Trap is generated when a generic type sensor detects an error. The sunHwTrapComponentName and sunHwTrapAdditionalInfo objects provide more information on the sensor and its value.
sunHwTrapComponentOk
Trap is generated when a generic-type sensor returns to its normal state. The sunHwTrapComponentName and sunHwTrapAdditionalInfo objects provide more information on the sensor and its value.
sunHwTrapDriveControllerError
Trap is generated when a drive controller sensor has detected an error.
sunHwTrapDriveControllerOk
Trap is generated when a drive controller has returned to its normal state.
sunHwTrapElectricalCurrentFatalThresholdExceeded
Trap is generated when current sensor reports that its value has gone above an upper fatal threshold value.
sunHwTrapElectricalCurrentFatalThresholdDeasserted
Trap is generated when current sensor reports that its value has gone below a lower fatal threshold value.
sunHwTrapElectricalCurrentCritThresholdExceeded
Trap is generated when current sensor reports that its value has gone above an upper critical threshold value.
sunHwTrapElectricalCurrentCritThresholdDeasserted
Trap is generated when current sensor reports that its value has gone below a lower critical threshold value.
sunHwTrapElectricalCurrentNonCritThresholdExceeded
Trap is generated when current sensor reports that its value has gone above an upper noncritical threshold value.
sunHwTrapElectricalCurrentOk
Trap is generated when current sensor reports that its value is in the normal operating range.
sunHwTrapFanSpeedFatalThresholdExceeded
Trap is generated when a fan speed sensor's value goes above an upper fatal threshold setting or below a lower fatal threshold value.
sunHwTrapFanSpeedFatalThresholdDeasserted
Trap is generated when a fan speed sensor's value goes below an upper fatal threshold setting or above a lower fatal threshold value.
sunHwTrapFanSpeedCritThresholdExceeded
Trap is generated when a fan speed sensor's value goes above an upper critical threshold setting or below a lower critical threshold value.
sunHwTrapFanSpeedCritThresholdDeasserted
Trap is generated when a fan speed sensor's value goes below an upper critical threshold setting or above a lower critical threshold value.
sunHwTrapFanSpeedNonCritThresholdExceeded
Trap is generated when a fan speed sensor's value goes above an upper noncritical threshold setting or below a lower noncritical threshold value.
sunHwTrapFanSpeedOk
Trap is generated when a fan speed sensor's value returns to its normal operating range.
sunHwTrapFanError
Trap is generated when a fan sensor has detected an error.
sunHwTrapFanOk
Trap is generated when a fan sensor has returned to its normal state.
sunHwTrapFruInserted
Trap is generated when a FRU such as a power supply or fan module is inserted into the system.
sunHwTrapFruRemoved
Trap is generated when a FRU such as a power supply or fan module is removed from the system.
sunHwTrapHardDriveError
Trap is generated when a hard drive sensor has detected an error.
sunHwTrapHAStateChange
Trap is generated when the high availability component identified by sunHwTrapSystemIdentifier has changed state.
sunHwTrapHardDriveOk
Trap is generated when a hard drive sensor has returned to its normal state.
sunHwTrapHardDriveStatus
sunHwTrapHeartbeat
Trap is generated when a heartbeat is used to verify the SNMP trap configuration.
sunHwTrapHostState
Trap is generated when host state has changed.
sunHwTrapHostPowerOnDenied
Trap is generated when a request to power on the host has been denied.
sunHwTrapHostPowerButtonDisabled
Trap is generated when a request to power on the host is being ignored because the button is disabled.
sunHwTrapHostPowerBootError
Trap is generated when a request to power on the host has failed due to a boot error.
sunHwTrapHostPowerOffLimitExceeded
Trap is generated when a shutdown initiated do to power limit being exceeded.
sunHwTrapHostPowerAction
Trap is generated when a state change in host power has taken place.
sunHwTrapIOError
Trap is generated when an I/O sensor has detected an error.
sunHwTrapIOOk
Trap is generated when an I/O sensor has returned to its normal state.
sunHwTrapMemoryError
Trap is generated when a memory sensor has detected an error.
sunHwTrapMemoryOk
Trap is generated when a memory sensor has returned to its normal state.
sunHwTrapPreOSError
Trap is generated when an error has been detected in the period before the OS has taken control of the system.
sunHwTrapPowerSupplyError
Trap is generated when a power supply sensor has detected an error.
sunHwTrapPowerSupplyOk
Trap is generated when power supply sensor has returned to its normal state.
sunHwTrapProcessorError
Trap is generated when a processor sensor has detected an error.
sunHwTrapProcessorOk
Trap is generated when a processor sensor has returned to its normal state.
sunHwTrapPowerConsumptionThresholdExceeded
Trap is generated when a power consumption threshold has been exceeded.
sunHwTrapPowerConsumptionThresholdDeasserted
Trap is generated when a power consumption threshold has been deasserted.
sunHwTrapPsuRedundancyLost
Trap is generated when PS redundancy is lost.
sunHwTrapPsuRedundancyRestored
Trap is generated when PS redundancy has been restored.
sunHwTrapSecurityIntrusion
Trap is generated when a intrusion sensor has detected that someone might have physically tampered with the system.
sunHwTrapSensorFatalThresholdExceeded
Trap is generated when a sensor reports that its value has gone above an upper critical threshold setting or below a lower critical threshold setting.
sunHwTrapSensorFatalThresholdDeasserted
Trap is generated when a sensor reports that its value has gone below an upper critical threshold setting or above a lower critical threshold setting.
sunHwTrapSensorCritThresholdExceeded
sunHwTrapSensorCritThresholdDeasserted
sunHwTrapSensorNonCritThresholdExceeded
Trap is generated when a sensor reports that its value has gone above an upper noncritical threshold setting or below a lower noncritical threshold setting.
sunHwTrapSensorThresholdOk
Trap is generated when a sensor reports that its value is in the normal operating range.
sunHwTrapSlotOrConnectorError
Trap is generated when a sensor associated with a slot or connector has detected an error.
sunHwTrapSlotOrConnectorOk
Trap is generated when a sensor associated with a slot or connector has returned to its normal state.
sunHwTrapStorageVolumeError
Trap is generated when a storage volume sensor has detected an error.
sunHwTrapStorageVolumeOk
Trap is generated when a storage volume has returned to its normal state.
sunHwTrapTempFatalThresholdExceeded
Trap is generated when a temperature sensor's value goes above an upper fatal threshold setting or below a lower fatal threshold value.
sunHwTrapTempFatalThresholdDeasserted
Trap is generated when a temperature sensor's value goes below an upper fatal threshold setting or above a lower fatal threshold value.
sunHwTrapTempCritThresholdExceeded
Trap is generated when a temperature sensor's value goes above an upper critical threshold setting or below a lower critical threshold value.
sunHwTrapTempCritThresholdDeasserted
Trap is generated when a temperature sensor's value goes below an upper critical threshold setting or above a lower critical threshold value.
sunHwTrapTempNonCritThresholdExceeded
Trap is generated when a temperature sensor's value goes above an upper noncritical threshold setting or below a lower noncritical threshold value.
sunHwTrapTempOk
Trap is generated when a temperature sensor's value returns to its normal operating range.
sunHwTrapTestTrap
Test trap.
sunHwTrapVoltageFatalThresholdExceeded
Trap is generated when a voltage sensor's value goes above an upper fatal threshold setting or below a lower fatal threshold value.
sunHwTrapVoltageFatalThresholdDeasserted
Trap is generated when a voltage sensor's value goes below an upper fatal threshold setting or above a lower fatal threshold value.
sunHwTrapVoltageCritThresholdExceeded
Trap is generated when a voltage sensor's value goes above an upper critical threshold setting or below a lower critical threshold value.
sunHwTrapVoltageCritThresholdDeasserted
Trap is generated when a voltage sensor's value goes below an upper critical threshold setting or above a lower critical threshold value.
sunHwTrapVoltageNonCritThresholdExceeded
Trap is generated when a voltage sensor's value goes above an upper noncritical threshold setting or below a lower noncritical threshold value.
sunHwTrapVoltageNonCritThresholdDeasserted
Trap is generated when a voltage sensor's value goes below an upper noncritical threshold setting or above a lower noncritical threshold value.
sunHwTrapVoltageOk
Trap is generated when a voltage sensor's value returns to its normal operating range.
Related Information
