The switch contains an SMTP email client which is used to email notification and alerts to specified email address. The email address can be an alias or individual recipient's email, for example, the switch administrator.
-> set /SP/clients/smtp address=IP_address customisers=email port=outnumber state=state
where:
IP_address is the IP address of the SMTP server.
email is the sender, as seen in the From field. For example, ilom-gwl@hostname, where hostname is the host name of the SP.
port is the port on which the SMTP server communication occurs.
state is either enabled or disabled.
For example, type:
-> set /SP/clients/smtp address=123.45.67.89 customisers=ilom-gwl@hostname state=enabled Set 'address' to '123.45.67.89' Set 'customisers' to 'ilom-gwl@hostname' Set 'state' to 'enabled' ->
