Filter the Oracle ILOM Audit Log By Using Predefined Conditions (Oracle ILOM
Web)
You can filter the Oracle ILOM Audit log so that it displays entries that
match a criterion you select. The switch has predefined filter criteria
based on subsystem and event type, but you also can create custom filters.
Use this task to filter the Oracle ILOM Audit log by predefined
conditions.
Choose ILOM Administration→Logs, and click the Audit tab.
From the Filter drop-down menu, select the filtering criterion.
To filter the Event log by all events, or to reset the Event
log to its original state after its been filtered, select All
Events.
To filter by all IPMI events, select Type:IPMI.
To filter by all user interface events, select Type:UI.
To filter by events that are persistent, not transitory,
select Type:Persistence.
To filter by all events related to an upgrade, select
Type:Upgrade.
To filter all events that are severity of major, select
Severity:Major.
To filter by all Audit Events, select All Audit Events.
To filter by all events related to the restricted shell,
select All RestrictedShell Events.
To filter by all events related to the captive shell, select
All CaptiveShell Events.
The log contains only entries that match the criterion you selected.
In the Rows Per Page field, type the number of rows that you want
displayed on each page.
The number of rows you set is not persistent across sessions, so if
you log out, the number of rows displayed per page resets to the default
value (25).
Click OK.
