Disable AD (Oracle ILOM Web)
You can selectively disable AD without having to delete or reset any of
the AD properties. When AD is disabled, AD users are disallowed access to
the switch.
Choose ILOM Administration→User Management, and click the Active
Directory tab.
Clear the Enabled checkbox for State.
Click Save.
