Oracle EDR InfiniBand Switch and Virtualized I/O Systems Administration Guide
Exit Print View
Updated: November 2016
Display the Host Power-Control Settings (Oracle ILOM Web)
Through Oracle ILOM, you can display and control host power by using the switch. If host power control is enabled, use this task to display power state of hosts.
  • Choose Host Management→Power Control.
    The text below Settings indicates the switch's current power state.
Related Information
