Load Certificate Information for an LDAP over SSL Server (Oracle ILOM
Web)
If strict certificate mode is enabled, you must upload the switch's
certificate.
Choose ILOM Administration→User Management, and click the LDAP
over SSL tab.
Click the Certificate Information link.
The pane scrolls to the Certificate Information section.
From the Transfer Method drop-down menu, select the desired transfer
method.
Provide additional information.
For Browser, click Browse and select the file.
For TFTP, provide the host name and file path.
For FTP, SFTP, SCP, HTTP, or HTTPS, provide the host name,
file path, username, and password.
For Paste, paste the text of the key into the Data
field.
Click Load Certificate.
Click Save.
