Firmware images in the switch are numbered, and the firmware for the Ethernet switch chip is number 2. For the Ethernet switch chip, you can use this task to load Ethernet switch chip firmware on an as needed basis.
-> set /System/Firmware/Other_Firmware/Firmware_2/ load_uri=firmware_uri ->
where firmware_uri is the URI for the firmware image you want to load on the Ethernet switch chip.
