If your network uses LDAP over SSL operator groups, you must configure those groups on the switch so that members of the operator groups can access the switch.
Operator groups configured on the LDAP over SSL server must match the groups configured on the switch
Group names must comply with standard LDAP over SSL name formats for operator groups.
The switch supports a maximum of five groups.
The pane scrolls to the Operator Groups section.
A pop-up window is displayed.
When entering the name, use commas to separate each information element, and do not use spaces. For example, CN=SpOperator,OU=Groups,DC=domain,DC=companyq,DC=com.
