The switch has a FIPS service that enables Oracle ILOM to use cryptographic algorithms in compliance with the FIPS 140-2 security standards issued by the National Institute of Standards and Technology (NIST). By default, FIPS is disabled. When you enable FIPS, some other services might not be available, for example, IPMI 1.5 sessions.
LDAP cannot be enabled if FIPS is enabled.
RADIUS cannot be enabled if FIPS is enabled.
IPMI 1.5 sessions cannot be enabled if FIPS is enabled.
To enable FIPS, you must reboot the SP, which also clears the configuration.
A pop-up window prompts you for confirmation.
The SP is reset. Any active sessions are terminated.
