Add Alternate AD Servers (Oracle ILOM Web)
Typically, AD deployments have multiple alternate AD servers. The switch
supports a maximum of five AD servers plus the primary.
Choose ILOM Administration→User Management, and then click the
Active Directory tab.
Click the Alternate Servers link.
The pane scrolls to the Alternate Servers section.
Click Edit.
A pop-up window is displayed.
Enter the IP address or host name of the alternate AD server.
Select the port for communication with the AD server:
Select the AutoSelect checkbox if you want the port
automatically determined.
Deselect the AutoSelect checkbox, and enter a port number in
the Port field if you want to specify the communication port.
Assign an SSL certificate to the AD server.
See Load Certificate Information for an AD Server (Oracle ILOM Web).
Note -
You can also remove an SSL certificate through this window, by
clicking Remove Certificate.
Click Save.
