You can selectively delete SNMP v1 or v2c communities without having to change other SNMP properties. When an SNMP community is deleted, that members of that community can no longer access the switch. Other SNMP communication (for example, traps or notifications) operates normally.
The page scrolls to the SNMP Communities table.
A dialog prompts you for confirmation.
