As an option, you can edit the key to add a comment.
-> set /SP/users/user/ssh/keys/X embedded_comment=comment ->
where:
user is the name of the user whose keys will be reset.
X is the number, from 1 to 5, of the key that will be reset.
comment is an alphanumeric comment string consisting of one word with no special characters, hyphens, or underscores.
For example, to embed the comment temporarykeyonly into the key for user1, type:
-> set /SP/users/root/ssh/keys/1 embedded_comment=temporarykeyonly Set 'embedded_comment' to 'temporarykeyonly' ->
