Alternate AD servers can also have SSL certificates that need to be loaded onto or removed from those servers. Use this task to manage the certificates for the alternate servers.
For example, to remove the certificate file from alternate server 1, type:
-> set /SP/clients/activedirectory/alternateservers/1/cert/ clear_action=true Are you sure you want to remove the cert (y/n)? y ->
For example, to load a certificate file onto alternate server 1, type:
-> load /SP/clients/activedirectory/cert/ load_uri=URI ->
where URI is the uniform resource indicator for the certificate file.
For example, to load the certificate file 112115.cert onto alternate server 1, type:
-> load /SP/clients/activedirectory/alternateservers/1/cert/ load_uri=ftp://root:changeme@123.45.67.89/privkeystore/112115.cert Load Successful. ->
