Enable AD (Oracle ILOM Web)
The switch has an AD client, which you must configure if the switch will
be operating in a network with AD servers.
Choose ILOM Administration→User Management, and click the Active
Directory tab.
Select the Enabled checkbox for State.
Type the IP address or host name of the active directory server in the
Address field.
Type the port for communication with the active directory server in
the Port field.
Select the AutoSelect checkbox (default) if you want the port
automatically determined.
Deselect the AutoSelect checkbox, and enter a port number in
the Port field if you want to specify the communication port.
Type the number of seconds in the Timeout field.
Configure operational modes as needed.
For these modes, select the Enabled checkbox for State:
Strict Certificate mode.
DNS Locator mode.
Expanded Search mode.
Strict Credential mode.
From the Log Detail drop-down menu, select the amount of detail you
want included in logs.
Click Save.
