Enable LDAP over SSL (Oracle ILOM Web)
The switch has an LDAP over SSL client that can grant access to
authenticated and authorized LDAP over SSL users. Authorization occurs in
either of these ways:
Simple authorization, which uses standard roles in the Oracle
ILOM.
Remote server authorization, which uses one or more LDAP over SSL
configured groups. These groups must contains users, and the groups
must be configured on the LDAP over SSL authentication server before
configuring the groups on the switch.
You must have user management role (u) to configure LDAP over SSL and its
properties on the switch.
Choose ILOM Administration→User Management, and click the LDAP
over SSL tab.
Select the Enabled checkbox for State.
In the Address field, type the IP address or host name of the LDAP
server.
Select the port for communication with the LDAP server.
Select the AutoSelect checkbox if you want the port
automatically determined.
Deselect the AutoSelect checkbox, and enter a port number in
the Port field, if you want to specify the communication port.
Type the number of seconds in the Timeout field.
If Strict Certificate mode is required, select the Strict Mapping Mode
checkbox.
(Optional) If you want to configure User Mappings, select the
checkbox.
See (Optional) Configure LDAP over SSL User Mappings (Oracle ILOM Web).
From the Log Detail drop-down menu, select the amount of detail you
want included in logs.
Click Save.
