Oracle EDR InfiniBand Switch and Virtualized I/O Systems Administration Guide
Exit Print View
Updated: November 2016
Display the Battery Power Information (Oracle ILOM CLI)
The switch contains a battery that provides standby power in conditions where the switch does not have constant power from the facility, for example, when the switch is powered off or resetting.
  • Display the voltage information for the switch's battery.
    -> show -d properties /SYS/MB/V_VBAT
     /SYS/MB/V_VBAT
     	Properties:
     		type = Voltage
     		ipmi_name = MB/V_VBAT
     		class = Threshold Sensor
     		value = 3.047 Volts
     		lower_noncritical_threshold = 2.548 Volts
    		 upper_nonrecov_threshold = N/A
            	upper_critical_threshold = N/A
            	upper_noncritical_threshold = N/A
            	lower_critical_threshold = N/A
            	lower_nonrecov_threshold = N/A
     		alarm_status = cleared
Related Information
