You can selectively disable the SSH server on the switch at any time without having to
change the SSH configuration. When SSH is disabled, the switch terminates all active SSH CLI
sessions running on the SP.
Type:
-> set /SP/services/ssh/ state=disabled
Set 'state' to 'disabled'
