If your network uses LDAP over SSL administrator groups, you must configure those groups on the switch so that members of the administrator group can access the switch.
Administrator groups configured on the LDAP over SSL server must match the administrator groups configured on the switch.
Administrator group names must comply with the standard LDAP over SSL name formats for administrator groups.
The switch supports a maximum of five groups.
The pane scrolls to the Admin Groups section.
A pop-up window is displayed.
When entering the name, use commas to separate each information element, and do not use spaces. For example, CN=SpAdmin,OU=Groups,DC=domain,DC=companyq,DC=com.
