Through Oracle ILOM, the switch receives a default self-signed SSL certificate and corresponding keys. As an alternative, you can upload a nondefault SSL certificate and its paired private key in PEM format.
The pane displays the certificate status, default certificate, custom certificate, and private key installed on the switch.
