The switch has redundant power supply units (PSs) numbered 0 and 1 that you can monitor for output power conditions. Use this task to monitor information about an individual PS.
-> show -d properties /SYS/PS0/OUTPUT_POWER /SYS/PS0/OUTPUT_POWER Properties: type = Power Unit ipmi_name = PS0/OUTPUT_POWER class = Threshold Sensor value = Disabled upper_nonrecov_threshold = N/A upper_critical_threshold = N/A upper_noncritical_threshold = N/A lower_noncritical_threshold = N/A lower_critical_threshold = N/A lower_nonrecov_threshold = N/A alarm_status = indeterminate ->
-> show -d properties /SYS/PS0/I_OUT /SYS/PS0/I_OUT Properties: type = Current ipmi_name = PS0/I_OUT class = Threshold Sensor value = 14. 750 Amps upper_nonrecov_threshold = N/A upper_critical_threshold = N/A upper_noncritical_threshold = N/A lower_noncritical_threshold = N/A lower_critical_threshold = N/A lower_nonrecov_threshold = N/A alarm_status = cleared ->
-> show -d properties /SYS/PS0/V_OUT /SYS/PS0/V_OUT Properties: type = Voltage ipmi_name = PS0/V_OUT class = Threshold Sensor value = 12.00 Volts upper_nonrecov_threshold = 20.000 Volts upper_critical_threshold = 14.000 Volts upper_noncritical_threshold = 50.000 Amps lower_noncritical_threshold = N/A lower_critical_threshold = N/A lower_nonrecov_threshold = N/A lower_critical_threshold = 10.000 Volts alarm_status = cleared ->
