Exit Print View
You can disable SSO as needed. When disabled, every time you need to provide credentials to the switch you will be prompted for username and password.
-> set /SP/services/sso/ state=disabled Set 'state' to 'disabled' ->
Enable SSO (Oracle ILOM CLI)
Display the State of Single Sign-On (Oracle ILOM CLI)
