swift-container-info - info tool
swift-container-info [CONTAINER_DB_FILE] [SWIFT_DIR]
swift-container-info(1) OpenStack Swift swift-container-info(1)
NAME
swift-container-info - Openstack Swift container-info tool
SYNOPSIS
DESCRIPTION
This is a very simple swift tool that allows a swiftop engineer to
retrieve information about a container that is located on the storage
node. One calls the tool with a given container db file as it is
stored on the storage node system. It will then return several infor-
mation about that container such as;
- Account it belongs to
- Container
- Created timestamp
- Put timestamp
- Delete timestamp
- Object count
- Bytes used
- Reported put timestamp
- Reported delete timestamp
- Reported object count
- Reported bytes used
- Hash
- ID
- User metadata
- X-Container-Sync-Point 1
- X-Container-Sync-Point 2
- Location on the ring
DOCUMENTATION
More documentation about Openstack Swift can be found at
http://swift.openstack.org/index.html
ATTRIBUTES
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | cloud/openstack/swift |
|Stability | Uncommitted |
SEE ALSO
swift-get-nodes(1), swift-object-info(1)
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original community
source was downloaded from http://launch-
pad.net/swift/kilo/2.2.2/+download/swift-2.2.2.tar.gz
Further information about this software can be found on the open source
community website at http://www.openstack.org/.
OpenStack 3/20/2013 swift-container-info(1)
