Network Management System User’s Guide
Audience
Related Documents
Conventions
Resources
Common Features
Launching Modules and Logging In
Launching an Application
Understanding User Types
Logging In
Understanding Common Features
Understanding Module Window Configuration
Using Date/Time Pickers
Working with Tables
Selecting and Deselecting Rows
Selecting a Single Row
Selecting Contiguous Rows
Selecting Noncontiguous Rows
Deselecting Rows
Understanding Column Display Options
Displaying Columns
Unlocking and Locking Columns
Copying Table Data
Exporting Table Data
Understanding Table Cell Tooltips
Sorting Data Tables
Using the Sort Dialog Box
Creating a User-Defined Sort
Quick Sorting
Filtering Data Tables
Creating and Editing Filters Using the Edit Filter Dialog Box
Creating a User-Defined Filter
Editing and Renaming Filters
Deleting a Filter
Understanding Operators
Dynamic Filtering
Auto Filtering
Organizing Filters and Folders
Showing, Hiding, and Revealing the Filters Pane
Creating Folders and Sub Folders
Moving and Copying Filters and Folders
Favorite Filters
Understanding Printing in Oracle Utilities Network Management System
Setting Print Margins
Web Workspace
Getting Started with Web Workspace
Understanding the Web Workspace Window
Understanding the Web Workspace Menus and Toolbar
Understanding Annunciators
Understanding Windows, Frames, and Dock Panes
Creating Window Frames
Understanding Docked Panes and Standalone Window Tools
Adjusting Window Size
Switching Between Tools Using the Keyboard
Saving and Restoring Workspace Preferences
Saving Your Preferences
Restoring to Default Preferences
Managing Your Workspace Layout
Understanding the Manage Workspace Layouts Dialog Box
Understanding Conditional Formatting
Global and Personal Conditional Formatting
Applying Conditional Formatting to a Table
Conditional Formatting Dialog
Understanding the Edit Rule Dialog Box
Understanding Conditional Formatting Precedence Rules
Quick Start for Effective Conditional Formatting
Conditional Formatting Best Practice
Quickly Apply a Formatting Rule
Apply a Formatting Rule to More than One Cell
Apply a Formatting Rule Based on Multiple Matching Conditions
Add Personal Conditional Formatting
Promoting Personal Conditional Formatting to Global Formatting
Taking Authority for Control Zones
Using the Authority Tool
Authority Tool Fields
Authority Tool Menus
Subscribing to a Control Zone
Subscribing to an Authority Group
Unsubscribing from a Control Zone
Searching for a Zone
Changing the Rule Set
Creating an Event
Using the Work Agenda
Opening Work Agenda Windows
Understanding Work Agenda (Filtered) Views
Understanding Work Agenda Standard Global Filters
Using Work Agenda Menus and Toolbars
File Menu
Understanding Work Agenda Data Display
Understanding the Work Agenda Summary Row
Understanding the Work Agenda Events List
Sorting, Selecting, and Locking Events List Columns
Using the Events List Condensed and Sub-Events Views
Using the Work Agenda Reading Pane
Acknowledging Events
Using the Viewer
Starting the Viewer
Understanding the Viewer
Understanding the Viewer Drawing Area
Understanding the Viewer Message Area
Using the Viewer Menus and Toolbar
Additional Viewer Toolbar Options
Saving Viewer Preferences
Understanding Viewer Tooltips
Understanding Viewer Context Menu Options
Displaying Device Details
Viewing Device Attribute Information from the Viewer
About the Attributes Window
Understanding Viewer Coloring
Changing the Coloring Mode
Viewing the Color Legend
Viewing the Highlight Legend
Searching and Loading Viewer Maps
Using the Search Tool to Locate Map Areas and Objects
Loading and Unloading Viewer Maps
Navigating in the Viewer
Navigating Using Mouse Controls
Scaling Symbols and Text
Displaying Pointer Coordinates
Viewer Focus
Focus on Viewer Selection
Focus on Selection Made in another Window
Using Feeder Focus
Feeder Focus on Adjacent Feeders
Viewing One Line Feeder Schematics
Using Lens Windows
Behaviors of the Lens Window and Viewer Lens Area
Real-Time and Study Mode
Selecting Devices
Device Selection
Box Selection
Polygon Selection
Multiple Selections
Identifying Symbology
Device Symbology
Condition Symbology
Conductor Symbology
Violation and Warning Symbology
Off-Nominal (Abnormal) Status Symbology
SCADA Symbology
Hiding and Displaying Viewer Objects
Decluttering the Viewer
Hiding Conditions with Devices
Hide/Display Example
Executing Traces
Trace Types
Using the Trace Dialog Box
Executing a Trace
Inspecting Direct Connections and Navigating to Connected Objects
Inspecting Impedances with the Upstream Impedance Report
Using the Commissioning Tool
Commissioning and Decommissioning Devices
Selecting Pending Devices
Using the Commissioning Tool with Web Switching Management
Using the Assessment Tool
Launching the Assessment Tool
Assessment Tool Toolbar Button Actions
Marking Conductors as Assessed
Removing the Assessed Status from Conductors
Removing Conductors from the Lists
Using the Save Case Management Tool
Opening the Save Case Management Tool
Creating a New Save Case
Viewing an Existing Save Case
Viewing Device Event History
Understanding the Select Scope Pane
Understanding the Event History Pane
Understanding Operations Event Note Pane
Using the Control Tool
Understanding the Control Tool
Control Tool Actions
Highlighting Events in the Work Agenda
Viewing Documents Associated with a Device
Adding Notes
Notes Dialog Box
Creating a Note
Editing a Note
Deleting a Note
Toggling Call Display
Viewing Associated Customers
Operating Devices
Opening a Device
Closing a Device
Instructing Actions
Instructed Actions Pane
Tagging Devices
Understanding the Tags Dialog Box
Placing an Editable Tag
Placing a Non-Editable Tag
Removing a Tag
Editing Editable Tags
Placing Grounds
Grounding a Device
Removing a Ground from a Device
Disabling Automatic Throwover (ATO) Switches
Placing a DISABLED Condition
Removing a DISABLED Condition
Disabling Network Protectors
Placing in Manual Mode
Placing in Disabled Mode
Restoring to Normal Mode
Placing Jumpers
Prompt Options
Inserting a Jumper
Operating a Jumper
Removing a Jumper
Placing/Performing a Tap Edit
Adding a Temporary Generator
Entering Model Attribute Values
Repredicting Upstream/Downstream
Creating Momentary Outages
Using Aggregate Device Actions
Using the Look Ahead Dialog Box
Understanding the Look Ahead Process
Understanding the Look Ahead Dialog Box
Associating Documents with Devices
Using the Manage Documents Window
Associating a Document with a Device
Removing a Document Association
Associating Damage Assessments to a Device
Completing and Instructing Actions
Condition Summaries
Using the Condition Summaries Window
Toolbar and Menu Options
File Menu
Sort Menu
Actions Menu
Help Menu
Using the Conditions Summary Filter Pane
Using Condition Summaries Balloon Details
Editing Conditions
Using the Alarm Displays
Understanding the Alarms List
Alarms Tool Menus and Toolbar
Alarm Priority Pane
Alarms Table
Alarms Filters Applied
Working with Alarms
Understanding the Abnormal Devices List
Understanding the Alarm History List
Using the User Log
Menus and Toolbar
File Menu
Actions Menu
Help Menu
Adding Entries to the User Log
Adding New User Log Entries
Adding an Associated User Log Entry
Changing Entry Type Before Submitting User Log Entry
Managing Events with Web Trouble Management
Understanding Event Details
Menus and Toolbar
File Menu
Actions Menu
Understanding the Event Information Pane
Updating the Estimated Restoration Time
Understanding Event Details Tabs
Using the Job Actions Tab
Using the Operations Event Note Pane
Using the Completion Actions Tab
Using the Equipment Failure Tab
Recording Failed Equipment Information
Using the Trouble Info Tab
Trouble Info Tab Menus and Toolbar Icons
Trouble Info Filter Pane
Using the Trouble Info Callers View
Using the Trouble Info Customers View
Using the Trouble Info Supply Points View
Using the Trouble Info AMI Customers View
Using the Damage Assessments Tab
Understanding the Damage Summary Pane
Understanding the Damage Assessments Table
Using the Event Log Tab
Using the Steps Tab
Steps Tab Toolbar and Context Menus
Step Columns
Using the Fault Location Analysis Tab
Using the FLISR Report Tab
Using the Optimization Report Tab
Using the Attachments Tab
Understanding the Attachments Tab Actions
Understanding the Attachments Tab Table Columns
Using the Update Events Window
Updating Multiple Events
Copying Event Details to Related Partial Restoration Events
Completing an Event
Confirm and Restore Outages
Using the Confirm Outages Window
Accessing the Confirm Outages Window
Understanding the Confirm Outages Window Color Coding
Confirm Outages Menus and Toolbar
Creating a Confirmed Service Outage
Creating a Confirmed Secondary Outage
Creating a Confirmed Service and Secondary Outage for the Same Customer
Restoring a Customer with a Confirmed Service or Secondary Outage
Setting Work Queues
Understanding Event Grouping
Group Events Dialog Box
Grouping Events
Understanding Grouping Rules
Graphical Grouping (Supply Points Mode)
Behavior of Grouped Events
Relating Events
Unrelating Events
Ungrouping Events
Associating and Unassociating Calls with Devices or Control Zones
Associating Fuzzy Calls
Unassociating/Reassociating a Call from/to a Device
Working with Stable Predictions
Working with Damage Assessments
Understanding the Damage Assessment Window
Menu and Toolbar Icons
Understanding the Damage Location Section
Understanding the Damage Specifics Section
Understanding the Damaged Assets Section
Understanding the Attachments Section
Creating Fuzzy Damage Assessments
Working with AMI Requests
Displaying the AMI Requests List
Creating AMI Requests
Creating AMI Requests for Service Outages
Creating AMI Requests for Device Outages
Creating an AMI Request Without an Outage
Completing AMI Requests
Canceling AMI Requests
Re-submitting AMI Requests
Updating the ERT for Selected Events
Clearing the ERT
Working with the System‑Wide Estimated Restoration Time
Setting the System-Wide Estimated Restoration Time
Clearing the System-Wide Estimated Restoration Time
Using the Trouble Summary
Menus and Toolbars
File Menu
Help Menu
Outage Summary Data
Damage Summary Data
Assessment Summary Data
Understanding the Trend Graph
Managing Crews with Web Trouble Management
Using Crew Actions
Understanding the Crew Actions Window
Menu and Toolbar
Filtering Crew Lists
Understanding Crew Actions Views
Understanding the Crew List View
Understanding the Crew Icons View
Understanding Crew Actions Operations
Activating a Crew
Setting a Crew's Status to On Shift
Setting a Crew's Status to Off Shift
Making a Crew Inactive
Deleting a Crew
Changing Crew Availability
Finding the Event a Crew is En Route To
Transferring a Crew to a Temporary Control Zone
Returning Control of a Transferred Crew
Using Crew Makeup
Understanding the Crew Makeup Window Components
Creating a New Crew
Removing Personnel from a Crew
Removing a Vehicle from a Crew
Editing a Crew
Managing Crew Operations
Assigning a Crew to an Event
Placing a Crew En Route
Placing a Crew Onsite
Placing a Crew Offsite
Suspending a Crew
Releasing a Crew
Crew Operations Using the Advanced Option
Using Crew Info
Opening Crew Info
Understanding Crew Info Window Components
Understanding Crew Info Fields and Buttons
Understanding the Crew Info Personnel Section
Understanding the Crew Info Vehicles/Equipment Section
Understanding the Crew Info Active Jobs Section
Understanding the Crew Info Current Assignment Section
Working with Crew Assignments
Modifying a Crew Assignment Duration
Changing the Crew Assignment Order
Unassigning a Crew
Placing a Crew En Route to an Assigned Event
Placing a Crew En Route from the Crew Actions Window
Placing a Crew En Route from the Viewer
Placing a Crew En Route from Crew Info
Updating Active Job Event Information
Moving a Crew
Moving a Crew from the Crew Actions Window
Moving a Crew from the Viewer
Moving a Crew from Crew Info
Releasing Crews from an Event
Releasing a Crew from the Active Jobs Pane
Releasing Crews from an Event Selected in the Work Agenda
Releasing a Crew from the Crew Symbol in the Viewer
Releasing Crews from an Event Symbol in the Viewer
Suspending a Crew
Bulk Crew Loading and Deleting (Administrative Users)
Options
Crew CSV Columns
Crew Member CSV Columns
Crew Vehicles CSV Columns
Using Bulk Add/Delete Scripts
Examples
Web Call Entry
Using Web Call Entry
Menus and Toolbars
File Menu
Actions Menu
Options Menu
User Menu
Help Menu
Field Descriptions
Searchable Information
Intersection Search Section
Additional Customer Information
Appointment Request
Callback Request
Request
Customer Comment
Event Information
Crew Information
Planned Outages Information
Searching for a Customer
Searching for a Customer Using the Call ID
Search for a Call using Caller Information
Viewing Call History
Call History User Interface
Call History
Viewing Event History
Cause Factors
Entering a Customer Call
Entering an Informational Call
Entering a Fuzzy Call
Canceling a Customer Call
Canceling All Calls For a Customer Account
Viewing the Outages Summary
Web Callbacks
Overview
The Web Callbacks Window
Menus and Toolbars
Actions Menu
User Menu
Help Menu
Header
Callbacks Table
Callbacks Table Column Features
Callbacks Summary Pane
Assigning Callbacks
Using the Assign Callbacks Window
Assigning Callbacks to Users
Assigning Numbers of Callbacks
Assigning Percentages of Callbacks
Assigning All Remaining Callbacks
Reassigning All Remaining Callbacks
Viewing Callback Assignments
View My Callback Lists Window
Viewing Your Callback Assignments
Canceling Your Callback Assignments
Unassigning Callbacks
Unassigning Callbacks for a Specific Event
Unassigning All of Your Callbacks
Performing Callbacks
Accessing the Perform Callback List
Using the Perform Callbacks List Window
Performing Assigned Callbacks for an Event
Performing Unassigned Callbacks (Next Callback)
Using the Perform Next Callback Window
Performing the Next Unassigned Callback for an Event
Storm Management
Getting Started with Storm Management
Storm Management Full Operations Environment
User Interface Features
Menus
User Menu
Status Bar
Storm Management Information Panes
Storm Management Information Overview
Storm Management Modes
Non-Storm Mode
Storm Mode
Storm Information
Storm Report
Summary Information
Zone Selection
Selecting the Control Zone to View
Using Storm Management
Using ERT Overrides
ERT Override Dialog Box
Turning Off Accessibility of the Estimates
Overriding the Estimates
Changing Publish/Non-Publish or Default ERT Information
Turning Accessibility of Projections Back On/Removing Overrides
Printing ERT Overrides
Manual Overrides
Overriding Historical Averages
Using Storm Mode
Entering Storm Mode
Using Define Storm Dialog
Placing a Control Zone in Storm Mode and Defining the Storm Information
Joining Existing Storms
Joining a Control Zone to an Existing Storm
Changing Storm Levels
Changing Storm Types
Forecasting Outages
Using Forecast Profiles
Working with Crew Information
Using Study Mode
Exiting Storm Mode
Storm Management View Only Environment
View Only Environment User Interface
View Only Menus
Storm Management Storm Administration Environment
Administration Environment User Interface Features
Administration Menus
Storm Administration Table
Printing the Storm Administration Table
Editing Storm Records
Excludable Period Dialog
Understanding Storm Management Calculations
How Storm Management Works
Historical Averages
Simulation
Storm Management Window
Non-Storm Mode Algorithm
Non-Storm Mode Algorithm Flow Chart
Service Alert Administration
Overview
Using the Service Alert Administration Tool
General Features
User Menu
Help Menu
Contact Manager
Contact Manager Tab
Adding a Contact
Editing a Contact
Removing a Contact
Group Manager
Group Manager Tab
Adding a Group
Removing a Group
Adding a Contact to a Group
Removing a Contact from a Group
Modifying the Message Transformation File
Parameter Manager
Parameter Manager Tab
About Parameter Values
Adding a Customer Count Parameter
Adding a Specific Customer Parameter
Adding a Frequency of Outages Parameter
Adding a Storm Affecting Control Zone Parameter
Editing a Parameter
Removing a Parameter
Utility Customer Manager
Utility Customers Tab
Adding Accounts
Adding an Account to Service Alert
Searching for an Account
Searching for an Account in Service Alert
Editing an Account
Removing an Account
Editing Customer Device Information
Adding Customer Contact Information
Searching for a Customer Contact
Searching for a Customer Contact in Service Alert
Editing Customer Contact Information
Removing Customer Contact Information
Adding Customer Contact Phone Information
Editing Customer Contact Phone Information
Removing Customer Contact Phone Information
Attribute Manager
Attributes Manager Tab
Adding Attributes
Editing a Attribute
Removing a Attribute
SCADA Extensions
Overview
Understanding SCADA Measurements
Understanding Measurement Quality Codes
Accessing and Using SCADA Features
Using the SCADA Status Window and Configuration Tools
Understanding the SCADA Status Window
Understanding the SCADA Status Window Menus
Understanding the SCADA Status Tree View Pane
Understanding the FEP Monitor
Understanding the FEP Details
Understanding the IED Monitor
Understanding IED Details
Understanding the Point Monitor Tab
Understanding the IED Templates Tab
Understanding the Audit Log Tab
Understanding the Debug Log Window
Using the SCADA Summary
Understanding the SCADA Summary Window
Understanding the SCADA Summary Filter Pane
Viewing Data in the SCADA Summary
Viewing All SCADA Data
Viewing SCADA Data for a Selected Device
Preventing Measurement Updates
Manual Entry and Override of SCADA Measurement Values
Adding and Modifying Comments for SCADA Status Changes
Disabling/Enabling Measurements in the Power Flow Solution
SCADA Measurements Trend Graph
Menus and Toolbar Buttons
Choosing the Analog Measurements to Display in the Viewer
Understanding SCADA Information in the Viewer
Enabling/Disabling SCADA Measurements in the Viewer
Choosing the SCADA Information Display
Displaying SCADA Measurements with Device Details
Remote SCADA Operation Warnings
Using SCADA Control Tool Features
Switching Management SCADA Integration
Vendor-Specific SCADA Integrations
OSI SCADA Integration
Cross UI Navigation
Overview
Operating Modes
Device Associations with Nominal and Current Network Components
Understanding Web Switching Management Windows
Overview
Web Switching Sheets
Switching Sheet Types
Switching Sheet States
Switching Sheet Window Components
Menu and Toolbar Features
Switching Sheet Tabs
Status Bar
Planned Switching
Creating a Planned Switching Sheet
Using the New Switching Sheet Window
Understanding Switching Sheet Templates
Creating a Switching Sheet Template
Understanding the Template ID Field
Creating a Switching Sheet from a Template
Switching Sheet Requests
Capabilities of the Switching Request User Type
Completing the Request Tab
Taking Ownership
Changing the Switching Sheet State
Replication
Rework
Adding and Editing Steps
Steps Tab
Assigning Crews to a Switching Sheet
Switching Sheet Step States
Adding Recorded Steps to a Switching Sheet
Adding Steps Manually
Adding Comment Steps
Resetting Operation Text
Copying and Pasting Steps
Creating Go-Back Steps
Working with Blocks
Grouping and Ungrouping Steps
Linking and Unlinking a Step to Safety Document
Step Order Execution Rules
Editing Existing Steps
Finding and Replacing a Device in the Steps
Finding and Replacing Text in the Steps
Changing Start Date
Focusing on a Device in a Step
Example Return to Nominal Scenarios
Reviewing a Switching Sheet in Study Mode
Replaying Steps
Implementing a Planned Switching Sheet
Scheduling a Planned Master Event
Issuing a Switching Sheet
Printing the Switching Sheet
Instructing and Completing Switching Sheet Steps
Moving a Crew
Working with Switching Sheet Versions
Step Versioning
Viewing Impacted Customers
Using the Impacted Customers Tab
Color Coding
Generating the List
Sorting Impacted Customers List
Deleting and Restoring Customers from the List
Moving Customers
Checking for Overlaps
Using the Overlaps Tab
Color Coding
Updating the Overlaps List
Viewing an Overlapping Switching Sheet
Saving and Loading View Areas
Using the View Areas Tab
Saving a Viewing Area
Loading a Saved Viewing Area
Reloading all Auto-Load Viewing Areas
Deleting a Saved Viewing Area
Viewing the Audit Log
Adding a Comment to the Audit Log
Emailing Switching Sheet Data
Automatic Emails
Adding External Documents to a Switching Sheet
Using the External Documents Tab
Adding an External Document
Removing an External Document
Saving an External Document to Another Location
Saving a Selection of External Documents to Another Location
Opening and Editing an External Document
Troubleshooting Issues with External Documents
Opening an Existing Switching Sheet
Open a Switching Sheet Window from Switching Sheet List
Open Switching Sheet using Switching Sheet Search
Copying a Switching Sheet
Deleting a Switching Sheet
Power Flow Analysis in Switching Management
Starting the Power Flow Analysis Tool
Understanding the Power Flow Analysis Tool Window
Emergency Switching
Creating an Emergency Switching Sheet
Open or Create New Switching Sheet
Recording Emergency Operations
Understanding the Switching Sheet List
File Menu
Sort Menu
Actions Menu
Help Menu
Switching Sheet List Data Fields
Understanding the Switching Switch List Filter Pane
Opening Locked Documents
Stealing Locks
Event Associations
Hard Associations
Soft Associations
Rules for Grouping Event Associations
Exporting/Importing Switching Sheets
Crew Assignments
System Crews
Contractors
Working with Safety Documents
Understanding Safety Document Types
Mapping Step Types to Safety Document Types
Using Safety Documents in Switching Plans
Understanding the Safety Documents Tab
Safety Document Dialog Overview
Creating a Safety Document from a Switching Sheet
Assigning Crews to a Safety Document
Adding a Safety State Transition Step
Editing the Device List
Executing Safety State Transition Steps
Issuing Safety Documents
Releasing Safety Documents
Delegating Control of a Network Area
Safety Document List
File Menu
Sort Menu
Actions Menu
Help Menu
Safety Document List Data Fields
Understanding the Safety Document List Filter Pane
Opening Existing Safety Documents
From the Web Workspace File Menu
From the Web Workspace Search Safety Document Dialog
Open a Safety Document from an Open Switching Sheet
Open a Safety Document from a Switching Step on the Steps Tab
Open a Safety Document from the Control Tool
Completing Safety Documents
Aborting Safety Documents
Switching Sheet Associations
Outage Correction
Correcting Outages in a Rework Sheet
Using Outage Correction Sheets
Re-Recording the Outage Restoration Sequence in Study Mode
Outage Correction Error Codes
Using the Miscellaneous Log
Displaying the Miscellaneous Log
Filtering the Log
Editing the Miscellaneous Log Steps
Viewing Global Overlaps
Web Safety
Understanding the Stand Alone Safety Document Window
Safety Document Fields
Creating New Stand Alone Safety Documents
Creating a Safety Document from the Web Workspace
Creating a New Safety Document from the Control Tool
Using Stand Alone Safety Documents
Record Tag Operations
Record Ground Operations
Remove a Device from a Safety Document
Issuing, Releasing, and Completing a Safety Document
Loading a Safety Document
Deleting a Safety Document
Copying a Safety Document
Create a Safety Document in Study Mode
Associate an Existing Place Tag Action to a Safety Document
Power Flow
Introduction
Power Flow Solution Types and Frequency
Viewer Power Flow Information Visualization
Flow Direction
Line Catalog Information
Top Pane
Lower Pane
Seasonal and Temperature Based Limits
Seasonal Based Limits
Disconnected Distributed Energy Resources
Power Flow Results with Predicted Outages
Real-Time Power Flow Updates
Viewing Power Flow Results in Real Time
Understanding the Device Details Power Flow Results Data Table
Understanding Power Flow Results Table Data Indicators
Understanding Device Details for De‑Energized Devices
Power Flow Status Messages
Viewing Power Flow Results in Study Mode
Understanding the Power Flow Study Mode Load Scenario
Load Profile
Scaling Factor
Cold Load Pickup
Limits
Using Power Flow with Look Ahead
Power Flow Solutions Details
Viewing Power Flow Solution Details from the Viewer
Viewing Power Flow Solution Details from the Feeder Load Management Tool
Viewing Power Flow Solution Details from the Feeder Load Summary Tool
Using Power Flow Solution Details Window
Using the Conductor Impedance Mismatch Tool
Conductor Impedance Mismatch Tool Window
Menu and Toolbar Options
Understanding the Conductor Impedance Mismatch Tool Filter Pane
Conductor Impedance Mismatch Tool Report
Suggested Switching
Introduction
Suggested Switching Scenarios
Using the Suggested Switching Tool
Appending Steps to an Existing Switching Sheet
Selecting Devices
Starting the Suggested Switching Tool
Understanding the Suggested Switching Tool Window
Selecting a Plan Type
Unload Feeder
Load Scenario
Constraints
Feeder Ties
Plans
Summary
Using the Suggested Switching Solutions Tool
Suggested Switching Tool Menus and Toolbar Options
File Menu
Help Menu
Suggested Switching Solutions Tab
Toolbar Options
Suggested Switching Solutions Table
Feeder Contingency Analysis Tab
Toolbar Options
Feeder Contingency Analysis Table
Creating Switching Sheets with the Suggested Switching Solutions Tool
Appending Steps to a Switching Sheet with Suggested Switching Solution
Network Optimization Tool
Introduction
Understanding Optimization Weighting Factors
Using Optimization in Study Mode
Running Optimization in Study Mode
Options
Load Scenario
Result Plan
Summary
Using Optimization in Real-Time Mode
Setting the Optimization Mode
Understanding Optimization Events in the Work Agenda
Understanding the Number of Retries for a Timed Out Step
Configuring the Number of Retries for a Timed Out Step (Administration Users)
Aborting an Optimization Plan
Tracking Number of Operations on Capacitors and Penalizing Them
Configuration (Administration Users)
Viewing the Optimization Report
Optimization Report Menus and Buttons
File Menu
Actions Menu
Button
Understanding the Summary Pane
Summary Information
Optimization Messages
Recommendation Plan
Plan Details
Enabling and Disabling Optimization Devices from the Control Tool
Setting Optimization Mode on Feeders
AMI Bellwether Voltage
Overview
Usage in Optimization
Load Shed & Restoration
Introduction
Understanding the Load Shed and Restoration Tool
Menu and Toolbar
File Menu
Actions Menu
Help Menu
Selected Load Pane
Find Groups Pane
Load Groups Pane
Load Groups Table
Selecting Columns to View
Locking Columns
Using the Load Shed and Restoration Tool
Create a Load Shed Plan
Automatic Execution of SCADA Load Shed Steps
Deleting a Load Shed Plan
DERMS Dashboard
Understanding the DERMS Dashboard
Menus and Toolbar
File Menu
Actions Menu
Understanding the DERMS Summary Tab
System Summary Table
Weather Zone Summary Table
Utility DER Summary Table
Understanding the Weather Zone Forecasts Tab
Weather Zone Forecasts Table
Understanding the Utility DER Forecast Tab
Utility DER Forecasts Tab Layout
Utility DER Forecasts Table
Network Capacity Allocation Forecasts Table
Understanding Network Capacity Allocation
Data Requirements for Network Capacity Allocation
Overview
Feeder Load Management Modes
Using the Feeder Load Summary
Menus and Toolbar
File Menu
Actions Menu
View Menu
Help Menu
Status Bar
Understanding the Feeder Load Summary Data Table
Feeder Load Summary Filter Pane
Feeder Load Summary Table Columns
Feeder Conditions
Abnormal Conditions
Warnings and Violations
Conditions Coloring
Feeder Errors and Warnings
Using the Feeder Load Management Window
Accessing the Feeder Load Management Window
From a Viewer
From the Feeder Load Summary Window
Features of the Feeder Load Management Window
Menus and Toolbar
Status Bar
Graphical View Tab
Feeder Load Overview Tab
Forecast Accuracy Tab
Feeder Load Management Details
Using Real-Time and Study Mode
Viewing and Modifying Study Session Parameters
Feeder Load Management Options Pane
Limits Pane
Interval Pane
Buttons
Requesting a New Feeder Load Management Calculation
Data Source and Data Quality
Identifying Devices with SCADA Suspect and SCADA Inconclusive Results
Using the DMS Summary
Using the FLM Island Statistics Window
Fault Location, Isolation, and Service Restoration
Overview
Understanding FLISR Voltage Loss Detection Triggers
Understanding FLISR Blocking Conditions
Possible Blocking Scenarios
Understanding Sensitive Earth Fault Processing
Setting the System FLISR Mode
Understanding the FLISR Plan Execution Time Limit
Enabling and Disabling FLISR Devices from the Control Tool
Understanding FLISR Events in the Work Agenda
Aborting a FLISR Plan from the Work Agenda
Using the FLISR Report Tab in Event Details
FLISR Report Tool Menus and Toolbar
File Menu
Actions Menu
Context Menu Actions
Executing FLISR in Automatic Mode
FLISR Automatic Mode with Violations
Generating a Switch Plan for the Violation Case
Generating a Switch Plan with FLISR in Manual Mode
Generating the Switch Plan
Viewing FLISR Conditions
Viewing FLISR Actions
Viewing FLISR Disabled Devices
Using the FLISR Flow Summary Window
Optimizing the Network with FLISR Preferred Plan
Fault Location Process Overview
Fault Location Algorithm
Using Fault Location Analysis
Understanding Fault Events in the Work Agenda
Using the Fault Location Analysis Tool
SCADA Measurements Section
FLA Messages Section
Possible Fault Locations Section
Confirming Fault Locations
Marking Fault Locations as Incorrect
Correcting a Fault Location
Isolate and Restore Option for a Confirmed Fault
Manually Entering Fault Current from the Control Tool
Configuring Global FLA
Configuring Individual Feeders for FLA
Global FLA Versus Individual Feeder FLA Configuration
For Sustained Outages
Active Network Management Schemes
Introduction
Understanding ANMS Schemes
Overview of ANMS Scheme Creation
Understanding ANMS Modes
Global ANMS Mode
ANMS Template Specific Mode
Creating ANMS Switching Sheet Templates
Entering Conditions in the ANMS Conditions Tab
Selecting the Template's ANMS Mode
Deleting an ANMS Template
Understanding ANMS Events
Understanding ANMS Event Statuses
Understanding ANMS Event Status Transitions
Model Management
Overview
Using the Model Management Window
File Menu
Actions Menu
User Menu
Preferences Menu
Help Menu
Pending Map Section
Pending Map Actions
Patches Section
Status Bar
Model Management Actions
Displaying Map History
Displaying the Preprocessor Log
Building Maps
Rebuilding a Patch
Displaying the Patch Build Log
Displaying the Patch Build Report
Enabling and Disabling Model Building
Topology Validation Viewer
Topology Validation Viewer Window
File Menu
Action Menu
Help Menu
Running a Topology Validation Report
Dynamic Protection Schemes
Overview
Configuring Dynamic Protection Schemes
Understanding the Switch Protection Scheme Table
Understanding SCADA Measurements in Protection Schemes
Configuration Assistant, Event Management Rules
Global and Feeder Settings
Configuration Assistant, Feeder Management
Global DMS Settings
Displaying the Protection Scheme Settings
Viewing and Updating the Protection Scheme for a Device
Understanding Protection Scheme Events in the Work Agenda
Event Status Codes
DMS Status
Switching Plans
Closing Previous Protection Scheme Events
Periodic Protection Scheme Analysis
User Initiated Protection Scheme Analysis
Protection Schemes and Network Topology changes
Protection Schemes and FLISR
Protection Schemes and Suggested Switching
Protection Scheme Conditions
Default Relay
Getting Started with the Configuration Assistant
Understanding Configuration Assistant Menus and Toolbar
Using the User Administration Tab
Understanding the Current Users Pane
Adding a User
Editing a User
Removing a User
Saving Exported User Configuration
Understanding the User Type Memberships Pane
Product User Type Matrix
Changing User Type Memberships
Reorder Current User Types
Understanding the User Log Pane
Resetting a User Login
Using the User Permissions Tab
Understanding the Permissions (FlexOps & OMA) Pane
Adding Permissions
Editing Permissions
Removing Permissions
Using the Flex User Administration Tab
Understanding User Type Permissions Pane
Adding User Types and Assigning Permissions
Removing Permissions from a User Type
Controlling Permissions at a User Level
Using the Mobile User Administration Tab
Understanding the Mobile Users Pane
Mobile User Type Memberships
Current Keys
Permission Sets
Changing Permission Sets
Using the Mobile Applications Tab
Using the Event Management Rules Tab
Event Management Rules Components
Rule Categories Pane
Currently Configured Rules Pane
Documentation Pane
Working with Rules
Add a Rule to the Configuration
Edit a Rule in the Configuration
Remove a Rule from the Configuration
Export Configuration
Using the Event Details Options Tab
Event Details Options Pane
Adding an Options Pane Submenu
Adding an Option
Removing an Option
Editing an Option
Saving Exported Event Details Configuration
Reordering Options
Using the Schematica Options Tab
Understanding the Schematica Options Pane Components
Working with Schematica Options Tab Functions
Creating a Copy Pack
Adding an Option
Removing an Option
Editing an Option
Running the Schematic Generation
Saving Exported Schematica Options Configuration
Using the Feeder Management Tab
Menus
Actions Menu
NMS Feeder Management Table
Buttons
Modifying a Feeder DMS Application Mode
Changing Feeder Color
Using the State Transitions Tab
Viewing State Transitions
Example: New Damage Assessments State Transitions
Using the Default Restoration Times Tab
Device/Zone Default Restoration Times Pane
Columns
Buttons
Row Highlighting
Adding a Device/Zone-Based Default Restoration Time
Modifying a Device/Zone-Based Default Restoration Time
Deleting a Device/Zone-Based Default Restoration Time
Saving an Exported Default Restoration Time Configuration
Using the Limit Configuration Tab
Understanding the Limit Groups Table
Buttons
Understanding the Limit Sets Table
Buttons
Understanding the Limit Bands Table
Buttons
Using the Alarm Configuration Tab
Understanding the Behavior Tab
Alarm Behavior Table
Understanding the Add / Edit Alarm Definition Dialog Box
Understanding the Active Alarms List
Understanding the Mapping Tab
Buttons
Using the Add / Edit Alarm Mapping Dialog Box
Understanding the Priorities Tab
Buttons
Using the Add / Edit Alarm Priority Dialog Box
Understanding the Classes Tab
Using the Add / Edit Alarm Classes Dialog Box
Understanding the Categories Tab
Using the Add / Edit Alarm Categories Dialog Box
Understanding the Attributes Tab
Using the Add / Edit Attributes Dialog Box
Using the Customer Administration Tab
Menus and Toolbar
Actions Menu
Options Menu
Setting Debug
Columns
Manual Debug Entry
Using the Customer Administration Weighted Priority Editor
Editing a Customer Weighted Priority
Resetting Weighted Priority
NMS Training Simulator: Trainer Environment
NMS Training Simulator Overview
Getting Started with the Trainer Environment
Accessing the Training Simulator Environment
Logging In as Trainer
Creating Training Scenarios
Creating a Training Scenario Sheet
Understanding the Training Scenario Sheet
Recording Scenario Steps
Using the Training Environment Control Tool
Submitting Customer Calls
Adding Customer Calls with Web Call Entry
Simulating SCADA Input Changes Using the SCADA Summary
Resetting the Model
Saving the Training Scenario Sheet
Recording a Storm
Example: Record Historical Calls from October 29, 2012
Conducting Training Sessions
Running a Training Scenario
Starting a Training Scenario
Playing a Training Scenario
Pausing a Training Scenario
Replaying a Storm Scenario
Evaluating Trainee Performance
Operations Mobile Application
OMA Progressive Web App
Client PWA Installation Instructions
Client PWA Update Instructions
Client PWA Uninstall Instructions
Configuring OMA Login Settings
Login Settings Servers Tab
Login Settings App Tab
Logging In
How to Log In as an Existing User
How to Log In as a New User
Understanding and Selecting Your User Types
Understanding the Main Page - Full Operations User Type
Understanding the Tasks Tab
Understanding the Switching Tab - Full Operations User Type
Understanding the Safety Tab - Full Operations User Type
Understanding the Map Tab - Full Operations User Type
Understanding the Event Details Page - Full Operations User Type
Understanding the Event Info Tab
Understanding the Calls Tab
Understanding the Faults Tab
Understanding the Details Tab
Understanding the Damage Tab
Understanding the Main Menu - Full Operations User Type
Understanding Your Profile
Understanding Crews
Using the Documents Page
Understanding Settings
About
Logout
Flex Operations
Getting Started with Flex Operations
Logging In
Logging Out
Using the Authority Dialog Box
Understanding the Flex Operations Workspace
Understanding the Workspace Banner
Understanding the Tabbed User Interface
Understanding Common User Interactions
Understanding Common Table Features
Understanding Printing in Flex Operations
Managing Outage Events
Working with the Events and Crews Tool
Working with Event Details
Working with Events in Flex Operations
Managing Crews in Flex Operations
Working with the Map
Displaying the Map
Understanding Map Settings
Understanding Pan and Zoom Actions
Understanding Common Symbols
Map Menu Options
Map Hide/Display Options
Using the Map's Back and Forward Buttons
Searching and Positioning
Using the Distance Measurement Tool
Using the Geographic Location Tool
Displaying Tooltips
Selecting and Interacting with Map Objects using the Selection Panel
Get Directions or Access Other Map Views
Using the Trace Feature
Managing Damage Assessments
Understanding Damage Assessments
Understanding the DMS Status Summary
Understanding Switching in Flex Operations
Understanding Switching Sheets
Understanding Planned Switching Sheets in Flex Operations
Understanding Emergency Switching Sheets in Flex Operations
Understanding Step State Transitions in Flex Operations
Understanding the Switching Sheet 's Events List
Understanding the Switching Sheet 's Crews List
Understanding the Manual Steps Addition Form
Understanding Safety Documents in Flex Operations
Understanding the Safety Documents List
Accessibility Features
Understanding NMS Keyboard Navigation Methods
Link Selection
Using NMS with a Screen Reader
High Contrast
Screen Scaling
Acronyms
Event Status and Event Type Codes
Event Status Codes
Event Type Codes
Color Coding
Crew Status
Event Status
Feeder Automation Status
FLISR Status
Callback Status
Conductor Symbology
Feeder/Device Condition Names and Colors
SCADA Data Quality Codes and Colors
Tool to User Type Matrix
Web Workspace
Storm Management
Network Management System User’s Guide , Release 2.5.0.2.5
WWSortDialog
WWFilterDialog
WWEditFilterDialog
WWEman
WWManageWorkspaceLayouts
WWConditionalFormatting
WWAuthorityWindow
WWCreateEvent
WWWorkAgenda
WWLoadcompleteevent
WWLoadcompleteEventrange
WWViewerWindow
WWViewerDeviceInfo
WWViewerDeviceSCADA
PFFlowResults
ConnectedkVA
PFFaultDetails
PFRegulationSettings
DDViolations
DMSSettings
WWSearchDialog
WWChoosefeeder
ViewerChangeFocusFeeder
WWSelectdevice
WWHideDisplayDialog
WWTraceDialog
TraceResultsDialog
WWImpedanceReport
CommissioningTool
AssessmentTool
SaveCaseMgmt
WWControlTool
WWRegulationDeviceParametersDialog
WWConditionDataDialog
WWCreateEditableTags
WWGroundSecondarySelectionDialog
WWSelectSecondaryDialog
WWSelectionRequiredDialog
TempGeneratorDialog
ModelAttributesDialog
WWCreateMomentaryDialog
WWLookAheadWindow
WWLADropCountsTab
WWLAPickupCountsTab
WWLAATOCustomersTab
WWLAViewConditionsTab
WWLAViewAbnormalTab
WWLAViewCriticalTab
LAViewSpecialDevicesTab
LAViewViolationsTab
LAViewDERTab
LAViewDMSSettingsTab
WWManageDocs
WWConditionSummary
WWConditionEditDialog
WWAlarmsList
WWAbnormalDevicesList
WWAlarmHistoryList
WTUserLog
WTEventDetails
WTEDJobActionsTab
WTEDCompletionActionsTab
WTEDEquipmentFailureTab
WTTroubleInfoWindow
WTCallInfo
WWUngroupdialog
EditClues
WTMoveCustomers
DamageAssessmentsList
WTEventLog
WebSwitching_EventDetailsSteps
WTAttachments
WTEventDetailsDlg
WTConfirmOutages
WWREferral
WTGroupEvents
WWAssociateEvent
WWUnassociateDialog
DamageAssessment
WWSelectCrewdialog
WWSelectDamageLocation
WWAddLinkdialog
AMRRequest
WWAMRRejectedMetersDialog
WWIgnoredERT
WWGlobalERT
TroubleSummary
Graph
WTCrewList
WWSetCrewOnShiftDialog
WWSetCrewOffShiftDialog
WWUpdateCrewAvailability
Gantt
WTCrewMakeup
WTCrewInfo
WWUpdateAssignmentDuration
WebCallEntryWindow
WWIntersectionSearchDialog
WCECallHistoryWindow
WCEEventHistoryWindow
WWFuzzyCallDialog
WCEOutagesSummary
WebCallbacksWindow
AssignCallbacksWindow
ViewMyCallbackWindow
PerformCallbackWindow
PerformNextCallbackWindow
StormMgtFOE
WWERTOverride
WWForecastProfiles
WWImportCrew
WWCalculateCrews
WWDefineStorm
StormMgtVOE
StormMgtSAE
WWExcludableStormPeriod
ServiceAlertWindow
SAContactManagerTab
SAGroupManagerTab
SAParameterManagerTab
SAUtilityCustomersTab
SAAttributesManagerTab
ScadaStatus
ScadaFepMonitor
ScadaFepDetails
ScadaRtuMonitor
ScadaRtuDetails
ScadaPointMonitor
ScadaRtuTemplates
ScadaAuditLog
ScadaDebugLog
WWSCADASummary
WWManualEntryandoveride
WWEnableComments
SCADATrendGraph
WWControlComments
WSSwitchingEntryWindow
WSSwitchingMgtWindow
WebSwitching_UpdateStepDetails
WSNewWindow
WebSwitching_TemplateID
WSRequestTab
WebSwitching_ReplicateSwitchingSheets
WebSwitching_AutomaticallyCompleteReworkedSteps
WSStepsTab
WebSwitching_MoveStepToMiscLog
WSUpdateInstructDate
WWAddEventAssociation
SwmanSelectCrewDialog
WWSelectOperation
WWSelectGroundNode
WWAddCustomBlock
WWRenameCustomBlock
WebSwitching_CuttingEventSteps
WebSwitching_LinkSafetyFromStep
WWFindandReplaceDevice
WWFindandReplaceText
WWChangeStartDate
WSConfirmComplete
WSImpactedCustomersTab
WSMoveCustomers
WSOverlapsTab
WSViewAreasTab
WSTrackingAuditLogTab
WSExternalDocumentsTab
WSSearchWindow
WWDeviceSheets
WSCopyWindow
SWPFOptions
SWPFSummary
SwmanPfPlanDetails
WSOpenWindow
WWLockedObjectsDialog
WWStealLockedObjects
WSSafetyDocumentsTab
WSSafetyDocumentDialog
SelectDevicePhases
WebSafety_LinkStepToDoc
WebSafety_CreateDocFromStep
SafetyDocumentSelectCrewDialog
WWSafetyStateTransitionFailed
WWSafetyAddDevice
WWSafetyExecute
WSWConditionCheck
WSOpenSafetyWindow
WSSearchSafetyWindow
WWDeviceSafetyDocs
WSAssocSafetyDocument
WSWReworkSteps
WSMiscLog
WSGlobalOverlaps
WSStandAloneSafetyDocument
WSNewSafetyWindow
WebSafetyCopyDocument
LineCatalogInfo
PFRealTimeOptions
PFStudyModeOptions
PFSolutionDetails
ConductorImpedMismatchAnalysis
SSPlanType
SSUnloadFeeder
SSLoadScenario
SSConstraints
SSFeeders
SSPlans
SSPlanDetails
SSSummary
SSSolutions
VVOptions
VVConstraints
VVResultPlan
VVPlanDetails
VVSummary
VVReport
LoadShed
LoadShed_ExecutingLoadShedPlan
DermsDashboard
FLMFeederLoadSummary
FLMGraphicalView
FLMFeederLoadManagement
FLMAccuracyTab
FLMForecastAccuracyTrendGraph
WWDeviceViolations
WWTiePointCapacity
WWTransformers
WWShuntDevices
WWEquivSources
WWDistGens
WWLoadDetails
WWVoltageProfileGraph
FLMStudyModeOptions
DmsSummary
FLISRWindow
FLISR_GeneratingFlisrPlan
WWFLISRFlowSummary
FaultLocationWindow
CorrectFaultLocation
WWSelectReferenceDevice
WWFaultCurrentDialog
ModelManagementWindow
WWBuildMaps
WWPatchBuildlog
WWPatchBuildReport
TopologyValidationWindow
WWRunValidation
WWProtSchemeParametersDialog
WWProtSchemeBackgroundCheckDialog
CAWindow
CAUserAdminTab
CAMobileUserAdminTab
CAMobileApplicationTab
CASRSRulesTab
CAEventDetailsTab
CASchematicaTab
CADMSAppAdminTab
CAFeederManagementTab
CAStateTransitionsTab
CADefaultERT
CALimitConfigurationTab
CAAlarmConfigurationTab
CACustomerAdminTab
SetDebugDialog
Training_RecordStorm
FlexOps
